It is currently Fri 24 May 2024, 08:09
Post new topic Reply to topic  [ 78 posts ]  Go to page 1, 2, 3, 4  Next
 Post subject: HPI Baja 5B SS
PostPosted: Fri 22 May 2009, 18:45
Är ni redo.... http://www.youtube.com/watch?v=WPiqkJeb ... re=related
http://www.youtube.com/watch?v=OmCeQZfS ... re=related 8)
 Post subject: Vilken bjässe!
PostPosted: Sat 23 May 2009, 07:38
Kör: Mazda 5 2.0 6MT
Den där var rejält cool den =) Ser fram emot att se den i action. Har du beställt eller är du på gång att beställa? Du får lägga upp mycket bilder från monterandet så vi får vara delaktiga.
//Snowstorm
 Post subject: Re: Vilken bjässe!
PostPosted: Sat 23 May 2009, 09:43
//Snowstorm
Tjena.. :)
Jo den är betälld och betald..och på väg... 8)
Radiostyrningen ingår ej i denna i detta ss kit....men det kan man beställa härifrån.... ;)
http://www.mirageracing.com/
En skön film på eländet http://www.youtube.com/watch?v=vArJHJVn ... re=related
Klart det blir en ingående byggtråd....;)
Vi lär väl ses ... 8)
PostPosted: Sun 24 May 2009, 00:31
Lite info om modellen..!!
Product Details
HPI is proud to announce the Baja SS, a full-option Baja kit that you assemble yourself, loaded with tons of hop-ups that enhance the speed and power of the Baja 5B buggy, improve its durability even further, and provide totally sweet custom looks! The Baja SS follows the HPI innovation of upgraded Super Sport models that feature kit versions of popular HPI RTR models, with additional option parts added to enhance the enjoyment of your kit. A long list of option parts is included with the SS version of the Baja 5B. As you build the kit, you add in the options that come in the box, and add your own radio gear.
At the heart of the Baja SS is the Fuelie 26S, 26cc engine. With more displacement you get increased low-end grunt, more acceleration and huge top-end speed! To handle the extra horsepower of the Fuelie 26S, the drivetrain of the Baja SS is boosted with specially designed option parts that can handle the power increase.
Providing a boost of extra power is the Aluminium Tuned Pipe, which gives even more acceleration power to the Baja SS. To improve the handling of the Baja even further, a full set of new VVC/HD Baja shocks are included that improve handling on all types of terrain and are also heavy-duty to keep things secure on the track. A complete set of sway bars are included to keep your Baja SS planted in the curves and aid traction. To get more rear suspension travel at the rear, our designers have modified the rear shock tower brace - this gives you better rear traction and increased braking for lower lap times!
In addition to all the heavy duty options included with the kit, you get a tough, super-strong steering servo that is already equipped with the HP80584 Metal Gear Steering upgrade. This allows you to have the security of reliable, quick steering in all conditions. With a powerful servo controlling the steering, the Baja SS will track straight and true when you want it to, no matter how bumpy the running surface it.
Finally, we cant let the awesome good looks of the Baja SS go unannounced. Not only do you get the option Gunmetal Anodized Main Chassis, you get a full range of bright orange anodized aluminium 6061 T6 that are specific to the Baja SS. To top everything off, you get a clear bodyshell set that is totally ready for your custom paint scheme!
PostPosted: Sun 24 May 2009, 08:48
Kommer du att ha den i standardutförande eller kommer du lägga kaross på den? Såg att det fanns en rätt snygg. Karossen med belysning skulle ju vara fräckt =)
När kommer skönheten hit? Har du någon tidtabell?
//Snowstorm
PostPosted: Thu 28 May 2009, 18:04
Inom 3 veckor ungefär...!
Du menar om jag ska blinga den...! Antagligen kan man ju inte hålla sig i vanlig ordning! Såg att det fanns 30cc cylinder med kolv och matchande förgasare att beställa... :oops:
PostPosted: Tue 09 Jun 2009, 06:42
När är bilen färdig?!? :wink:
Väntar med spänning på en utförlig byggdagbok.
//Snowstorm
PostPosted: Tue 09 Jun 2009, 10:07
Bilder kommer i kväll.... ! Har framvagnen nästan färdig nu.. ;)
Uppdatering med bilder inom kort....! Men det blir mest bilder eftersom bygget fortskrider......! Så jobbigt att skriva..... :oops:
Men det kommer mycket bilder i stället :wink:
PostPosted: Wed 10 Jun 2009, 19:40
PostPosted: Wed 10 Jun 2009, 19:41
Bygget har är i sin linda.....! Men har nu börjat.. 8)
Lägger ut bilder först och kommenterar dem lite senare... !!
PostPosted: Wed 10 Jun 2009, 19:42
Tråkigt med så lite komentarer......!
Men vad kan man begära när man knappt kommenterat bilderna själv... 8)
Nåja....!!! Fortsätter min dokumentationstråd om itt Baja bygge......!!
Lite mer bilder.......!!
Det börjar likna en bil nu i allafall... :D
Kan nämna att allt..... å då menar jag allt har verkligen varit i molekyler.....! Har fått bygga Diffrentsialen själv..... och växelådan...!!
Alla plastdetaljer sitter fast i såna där plast-träd så man måste nypa av dem..och trimma till dem med en vass skalpell... men det tar man under arbetets gång!
Oj oj... vilken kvalitet på grejjerna raktigenom... och hur mycket stöd på nätet.. i form av eget baja forum och diverse custom tilverkare som har uppgraderings prylar till varenda pryl på bilen...!
Kan säga att en helt ny värld har öppnat sig för mig nu... :oops:
Kika in.... det är värt det.. ;) http://www.hpieurope.com/
Nej nu får det vara slutpladdrat... måste börja mata upp bilderna från i gårkväll.. natt... morgon.. :oops:
PostPosted: Wed 10 Jun 2009, 19:43
Denna bildserie börjar med bygget av diffrentsialen.... 8)
[img]http://www.motorportalen.n
PostPosted: Thu 11 Jun 2009, 00:51
Sista etappen..... 8)
Nu är jag helt utmattad...! Har haft bygg-marathon i 3 dygn...men nu är den äntligen färdig...!
Bara 2 saker kvar....! Köpa ratt-radio som ej följde med.. samt en brytare och ett batteri och en mottagare.... + målning med lexanfärg på karossen.. den är ju genomskinlig nu... :shock:
Bilder.... som utlovat...!!!
PostPosted: Thu 11 Jun 2009, 07:41
Försökte hitta ignorera knappen på den här tråden, men lyckades inte :D
Man ser att det ligger kvalitet i dom där bilarna.
Jag måste bara få se den där i action, säg till om du ska och köra någonstans så kan jag försöka komma med.
PostPosted: Thu 11 Jun 2009, 08:22
Jag hittar inte heller den där knappen, så man får väl titta i den här tråden då bara fast det är farligt :)
PostPosted: Thu 11 Jun 2009, 11:50
Blir väl en kommande körningar tråd i bil delen.. ;)
http://www.youtube.com/watch?v=sO5UMzApOuw&feature=fvw
PostPosted: Thu 11 Jun 2009, 14:19
Kör: cykel xD
J****r vad snabbt du byggde den! :o
Hoppas den går så där bra nu, som i alla filmer...
PostPosted: Thu 11 Jun 2009, 15:08
:lol:
PostPosted: Thu 11 Jun 2009, 19:07
Kamikaze brukar vara ivrig när han bygger och det går snabbt
och det är BRA, för då pinas man mindre när man läser tråden.
Det är över fort och man kan fortsätta med sitt vanliga liv efter
att bygger är klart. :D Habegäret hinner knappt upp på topp.
PostPosted: Thu 11 Jun 2009, 19:54
Nu har bling begäret kommit krypande... :) Det finns en uppsjö av färdiga bolt on motorer .. http://www.pro5thscale.com/complete_motors?b=1 som är färdigt portade och maxade i olika cc....! Kromade effektpipor i mängder.... http://www.pro5thscale.com/tuned_pipes?b=1 Kromade detaljer till i prinsip allt på bilen.... Gs. stötar.. schims kitt..... lager kit...... Olika karosser... i olika färgteman... färdig målade...! Led-ljus....! Broms-ljus.. att kopla in... så det lyser när man bromsar........Var ska dett sluta.... :oops:
Men fy faan va roligt att bygga baja....! 100 filmer..! Börjar med att han öppnar upp lådan.....! Slutar med att bajan e klar..! Man bygger den tillsammans med master i videon...! s*** bra.. och kul... och bekvämt! :.. han förklarar under byggets gång vilka delar som går att byta ut ... och fördelarna... och var man köper dem! Och vilka misstag man ska undvika att göra förklaras oxå under byggets gång! Man måte ha en otrolig ordning med sig och organisera upp alla påsar och grejjer innan man börjar bygget...! Annars blir det kaos...!
Så jäkla bra.... Prisat vare internet.... :lol: http://www.hpibajatutorials.com/forumdi ... 9e14a6&f=5
