It is currently Tue 21 May 2024, 16:00
 Post subject: Bygg din egen cub
PostPosted: Wed 04 Feb 2015, 23:20
http://www.cubcrafters.com/carboncubex 8)
Simply the best Cub kit available.
Nearly 300 pounds lighter and much stronger than an equivalent Super Cub.
Half the parts of a Super Cub means half the build time. Ready to cover in as few as 200 hours.
Compatible with engines up to 180 horsepower (!) while still qualifying as a Light Sport.*
Fuselage is four inches wider and the door is 50% larger for significantly increased comfort.
Absolutely complete airframe kit, including every necessary nut, bolt and washer.
Includes covering materials.
An excellent choice for the first-time builder.
*The builder is legal to fly the Carbon Cub EX as a "Light Sport" pilot as long as the kit is certified at a maximum weight of 1,320 lbs. Our kit was tested to ASTM standards at a gross weight of 1,865 lbs. If you decide to set the gross weight at 1,865 lbs, you will not be allowed to fly as a "Light Sport" pilot; and you will need a medical and a private pilots license.
 Post subject: Re: Bygg din egen cub
PostPosted: Wed 04 Feb 2015, 23:24
Jag bygger gärna ett flyg till, det var ett av det roligaste jag gjort. Kul projekt. Ser ut att vara mer lättbyggd än Skyrran. Köper du?
PostPosted: Wed 04 Feb 2015, 23:58
Ha ha...nej 8)
