It is currently Tue 21 May 2024, 00:50
 Post subject: Bra och prisvärda servon.
PostPosted: Tue 01 Jul 2008, 00:58
Futaba 3003 standardservo 122,00:-SEK
Bra och prisvärt standardservo.
Hastighet 0,23sek/60grader 4,8V
Styrka 3,2kg/cm vid 4,8V
Mått 41x20x36mm
Vikt 37,2g
Futaba 3010 High Torque Servo 315,00:-SEK
Ett starkt kullagrat servo i standardstorlek.
Hastighet 0,16sec/60 grader
6,5kg
Mått 40x20x38,1
Vikt 41g
Futaba 3050 digitalservo metalldrev 509,00:-SEK
This is the Futaba S3050 Digital Servo with Metal Gears.
Ideal for a wide variety of high-stress applications, including 1/8
and 1/10 scale off-roaders, boat rudders, and large-scale airplanes.
FEATURES: Durable metal gears
Digital technology gives performance advantage
INCLUDES: One S3050 Digital servo with preinstalled 0.83" (
21mm) round servo horn
Four Rectangular Grommets
Four Brass Bushings
Four 2 x 11mm Mounting Screws
One Large Round Horn, 1.4" (35mm) diameter
One Six Arm Horn, 1.2" (32mm) long
One Four Arm Horn, 1.5" (39mm) long
SPECS: Speed: .20 sec/60 ° at 4.8V, .16 sec/60 ° at 6V
Torque: 6,5kg at 4.8V,
Length: 1.57" (39.8mm) Width: 0.79" (20mm)
Height: 1.50" (38.1mm) Distance between center of mounting holes: 0.39" (9.9mm)
Weight: (49g)
Futaba 3152 digitalservo 359,00:-SEK
Mycket bra servo för både flygplan/bilar och helokopter.
Speciellt framtaget för att klara vibrationer!
Dimensions: 40x20x38.1 mm
Mass/weight: 42.50 g
Operating voltage: 4.8-6 Volts
Torque@4,8V: 5,2kg Torque@6V: 6,5kg
Transit speed: 0.17 Sec/45° Transit speed: 0.13 Sec/45°
Holding power: 13kg
